Topic: "Stems engine error" on M2 macbook
I've put a fresh install on a new m2 mba and receive a "stems engine error" popup on opening. Stems won't isolate and I'm also not able select "ezremix" or "moderneq" for eqing. Anyone that's recently updated found a fix to this?
geposted Sun 11 Dec 22 @ 5:02 am
I had the same thing happen to me on M1 MacBook Pro I installed some other software and I got the same error. I couldn't figure out how to fix it. I ended re formatting the computer and reinstalling VDJ . It's been fine ever since. I really the beta install of the other software I installed caused my issue.
