VDJ is auto beat matching & auto key matching, often making the vocals sound funny. Am I missing something here? Pioneer DDJ-1000SRT
geposted Sun 11 Dec 22 @ 6:40 pm
check out # 6 on this page of the manual for Virtual DJ
https://www.virtualdj.com/manuals/virtualdj/interface/decks/deckbasics.html
geposted Sun 11 Dec 22 @ 8:21 pm
Thanks, for the info, but that's not it. It only does it when connected too my controller. If it was that feature, wouldn't it do it without being hooked to a controller?
geposted Thu 05 Jan 23 @ 10:24 pm
So, it happens as soon as you load the 1st Track ( u see Key and/or BPM change) , or when you press PLAY ?
Happens during your mix at some point ?
The controller mapping doesnt force/change any of the VDJ settings, so check the following..
- setting autoKey is Off
- You are not pressing KEYLOCK. This would turn Master Tempo Off and would change the key of the Track while the tempo is changed ( https://www.virtualdj.com/manuals/hardware/pioneer/ddj1000srt/layout/decks.html Nr. 47)
- You are not using KEY SYNC (Nr. 48) - matches the Key of the other Track.
- You are not using SHIFT+KEYSYNC or SHIFT+KEYLOCK (they change the Track's key)
and most important, try with the factory default mapping , in case you have modified something by mistake.
geposted Thu 05 Jan 23 @ 10:41 pm
