Hi, Is there a way to have different action on Custom buttons on left and right side?
Thank you, Tomas.
Thank you, Tomas.
geposted Tue 13 Dec 22 @ 11:13 am
action_deck 1 ? ... : ...
geposted Tue 13 Dec 22 @ 12:18 pm
Thanks, tried Deckleft but not worked
geposted Tue 13 Dec 22 @ 12:19 pm
But same thing appears on both sides. What I want to do is to have different actions on both sides for custom button 1,2,3,4 using default skin, probably skin limitation
geposted Tue 13 Dec 22 @ 12:27 pm
Locodog gave you the answer, did you try that?
geposted Tue 13 Dec 22 @ 12:30 pm
Yes but I see same thing on left and right side
geposted Tue 13 Dec 22 @ 12:31 pm
Trying to have this on left
action_deck 1 ? clone_deck 3 & deck 1 stem_pad 'acapella' & deck 3 stem_pad 'instrumental'
and this on right side
action_deck 2 ? clone_deck 4 & deck 2 stem_pad 'acapella' & deck 4 stem_pad 'instrumental'
geposted Tue 13 Dec 22 @ 12:33 pm
Yes Locodog has posted the solution, unless you wish to mod the XML skin file.
This thread may be of interest:
https://virtualdj.com/forums/231772/VirtualDJ_Technical_Support/Custom_buttons_mirrored.html?search=%22custom_button%22&page=1.4
geposted Tue 13 Dec 22 @ 12:34 pm
geposted Tue 13 Dec 22 @ 12:37 pm
IIDEEJAYII thanks that wil be it
geposted Tue 13 Dec 22 @ 12:38 pm
name
`action_deck 1 ? get_text "left" : get_text "right"`
script
action_deck 1 ? clone_deck 3 & deck 1 stem_pad 'acapella' & deck 3 stem_pad 'instrumental' : action_deck 2 ? clone_deck 4 & deck 2 stem_pad 'acapella' & deck 4 stem_pad 'instrumental' :
script
geposted Tue 13 Dec 22 @ 1:29 pm
@LOCODOG
Thank you. Works great. Is there a way to have buttons lit deckcolor.
Regards Tomas
Regards Tomas
geposted Tue 13 Dec 22 @ 6:12 pm
