Topic: Auto Trigger Stems
I'm wondering if I can Auto Trigger Stems when it hits a certain cue spot of a song. I would like the vocals to turn off at a certain spot. Thanks!
geposted Tue 13 Dec 22 @ 1:38 pm
You absolutely can, via POI editor.
Just use an action POI and use stem_pad 'instrumental' as it's action.
To turn vocals back on use the same action on a second POI further down in time.
I actually made a video about it a while back:
Love the Padpage Klaus. Is it available in Extensions? I could not find it.
PS: you can currently also set the Name (and color) of the hotcue with:
.... & cue_name 21 'Mute 1 Short' & ...
or a workaround to sort of hide (till the day we have a script to set "invisibility" and/or "marker only" attributes, still a wish):
.... & cue_name 21 'Mute 1 Short' & cue_color 'black' & ...
I should probably add that :)
No, but there is a link to the pad page in the video description
Thanks Klaus, I didn't see that link since I was watching the embedded video (without the youtube comments).
I added the link from the video, for the padpage below, if others are interested:
Click>>> Mute Vocals Padpage, HERE
Again Thank you Klaus.. so Cool !
