Hello everyone, I own a Numark Party Mix which i have used for a couple years. A few months ago it randomly did not connect to VDJ and none of the buttons worked but it was still lighting up. The party mix has drivers that are automatically installed when you connect the device. I have tried different usb ports to no avail. You can't swap out the usb the device uses either. It does not come up on device manager but I'm not sure why if it lights up? This thing is really starting to annoy me and any help would be much appreciated as windows and VDJ is not recognizing it. (I'm on windows 11)
Cheers, David
Cheers, David
geposted Thu 15 Dec 22 @ 10:09 am
bump
geposted Wed 21 Dec 22 @ 2:51 am
Any other computer available to try ?
Does it work with other DJ software ?
Can you also try to see if MIDIOX (Google it) detects it and receive Midi messages ?
U mentioned Device Manager, do u get the device under Midi devices ?
geposted Wed 21 Dec 22 @ 3:08 am
