hello,
I have a running installation on MacBook i9 Pro 16.
Now I have a second MacBook Air M2.
the settings of my old MacBook Pro are located in iCloud under Documents/VirtualDJ?
where are settings of my MacBook Air, I have not found them on my drive?
Is it using the same folder, so I would run into issues overwriting the settings each other?
If yes, how can I avoid this Szenario?
geposted Fri 16 Dec 22 @ 3:59 pm
The VirtualDJ Home Folder may be different in fresh installations of VirtualDJ 2023.
the easiest way to get it is to open VirtualDJ, goto Settings->OPTIONs tab and then click on the small cog icon you ll find at the bottom-right of this tab
geposted Fri 16 Dec 22 @ 7:39 pm
Ok, this User/<Username>/Library/Application Support/VirtualDJ on my fresh Install.
geposted Sat 17 Dec 22 @ 7:24 pm
