My laptop doesn’t function with virtual dj now, I put the tracks I want in stems and it just lags like fuck. Why did they have to change it ? And where can I redownload the old version
geposted Fri 16 Dec 22 @ 6:34 pm
You can just disable stems in the settings and it'll just be like before
geposted Fri 16 Dec 22 @ 6:38 pm
Feel like the quality isn’t as good as it was before
geposted Fri 16 Dec 22 @ 6:53 pm
It's exactly the same.
geposted Fri 16 Dec 22 @ 7:07 pm
Nah I don’t think it is
geposted Fri 16 Dec 22 @ 7:31 pm
:-D
But it is
If you select reduced quality you get stems 1.0
geposted Fri 16 Dec 22 @ 10:12 pm
