There seems to be a bug with the latest update concerning database management. When you delete or remove the settings file in the documents folder (perhaps to reset the settings), it automatically deletes the database file, playlists, virtual folders, etc. in addition. Even after restoring the deleted settings file, all the above mentioned will still appear deleted (reset) and still will not reflect unless you revert back to Virtual DJ 2021, create an automatic local backup, follow the prompt to upgrade to VIRTUAL DJ 2023, and finally restore the local back up. Has anyone else experienced the same?
geposted Fri 16 Dec 22 @ 8:20 pm
Maybe it's because the missing settings file triggers the new VDJ homefolder being used?
geposted Fri 16 Dec 22 @ 10:06 pm
How do you fix it then?
geposted Sat 17 Dec 22 @ 2:43 am
