Topic: Inconsistent stems analysis times (RTX3050Ti) - Page: 2
Keith don’t you have a M1 Mac??
I know fxs are seriously lacking on that side but stems are flawless with it!
geposted Tue 20 Dec 22 @ 5:45 pm
My wife gas the M1 imac and my son has the M1 Macbook air.
May try a test to see how good it is.
Thanks for the info
geposted Tue 20 Dec 22 @ 5:52 pm
Yes definitely try it!! Trust me you will not be disappointed!!
geposted Tue 20 Dec 22 @ 5:53 pm
Huey, maybe I'm just unlucky.
Installed VDJ on the wife's M1, left everything at default as a clean install, loaded a 3 minute video file and it took 100 seconds to load the stem completely. That's insanely slow.
That was just real time, not saving the file as well.
geposted Tue 20 Dec 22 @ 6:23 pm
Was VDJ set to use the GPU? You are getting less then 2X.
Adion wrote :
M2 should be about 15x, so in-between the M1 (10x) and M1 Pro (20x)
geposted Tue 20 Dec 22 @ 6:39 pm
Yes, the don't use GPU was unticked.
geposted Tue 20 Dec 22 @ 7:06 pm
Have almost never used a Mac.. hopefully a Mac user will have a suggestion.
You are helping all who are looking to update their rigs..
by testing what seem to be great choices on paper.
Many thanks !
geposted Tue 20 Dec 22 @ 7:57 pm
I just can't stand MacOS. Being a long term Windows user it's just impossible to navigate.
The new Macbooks will be out early next year and will be even faster.
I guess it depends how much use you will get from stems, and for me personally it's mimimal so don't even know why I'm bothering really .......
geposted Tue 20 Dec 22 @ 8:00 pm
There are a few versions of the M1. I have the 14" m1 pro i just checked om my machine, a 4 minute 1080 video took 20 seconds to decode stems. The imac is an 8 core gpu vs the 14" macbook pro 16 core gpu. Either way 100 seconds seems insanely slow. My desktop i7 with rtx3060ti card was 1 second faster (19 seconds) decoding the same video.
Im not sure your price point , but this might be something windows based for you to look at although I dont know if the card is fast enough for you.
https://www.razer.com/gaming-laptops/Razer-Blade-15/RZ09-0421EED3-R3U1
geposted Tue 20 Dec 22 @ 11:00 pm
I guess I’ve never really paid attention to how long it takes to do a whole track.
From the time I have the track loaded to the time I press play it’s always been ready for me to use. I have never prepared any stems and just do everything on the fly.
I guess I’m not mixing whole tracks tho either so that could be the difference. It probably just comes down to our mixing styles.
geposted Sun 25 Dec 22 @ 7:57 pm
@Keith
I posted these results on another thread back in November using my 14" MacBook Pro;
Stems 2.0 generation on M1 MacBook Pro 16gb
Venbee, Goddard - Messy In Heaven (Official Video).mp4
Music video, length 3:00 minutes, stems completed = 15 seconds
Schak feat. Kim English - Moving All Around (Jumpin) [Extended Mix].mp3
mp3 length 7:08 minutes, stems completed = 25 seconds
Joel Corry, MNEK - Head & Heart (Extended Mix).m4a
Promo Only m4a length 4:05 minutes, stems completed = 15 seconds
Systems Specs;
Main System - MacBook Pro (14-inch, 2022), Apple Silicon M1 Pro, 16gb, 500 gb SSD, macOS Ventura 13.1, External WD Passport Ultra 2Tb HD formatted exFat containing Music & Video databases. VirtualDJ v2023-m b7388.
Controllers - Denon MC7000, Denon MC6000 Mk2.
geposted Sun 25 Dec 22 @ 8:53 pm
