when I had the last version of VDJ my song titles were fine. Now that I upgraded to 1.07b about 10% of my song titles are not there. then if I right click on the song and try to rename it the song title appears. Am I wacked or is there a bug?
geposted Thu 13 Nov 03 @ 11:28 pm
i dont know.but i know that if you delete internal database files from c/program files/virtualdj folder and restart it will work.i had problems with converting at 1.07 but not like that.
geposted Sat 15 Nov 03 @ 3:22 am
Do you get some wierd symbols in the titles/artist colums or you just don't see the titles at all. If that is the case, then it must be that you have that ID3 parser plugin installed. I had that same problem after I upgraded to 1.07b but the moment I un-installed it everything was fine.
I also noticed that after I un-installed the plugin, I could browse through my folders faster.
geposted Sun 16 Nov 03 @ 11:45 pm
