Topic: Music stops when loading another song
I'm using the newest version of windows. I purchased a new laptop a month ago. I'm using numark mixstream pro mixer. When I'm playing music on one deck, then loading a song on the other. The music stops until the song finishes loading. Idk what to do
geposted Thu 05 Jan 23 @ 12:12 am
try to disable real time stems in options and see if that fixes it
posting the laptops actual specs might help. new or not, the laptop might be too low spec to handle stems 2.0 and you'll either need to use precomputed stems or turn them off altogether.
reading the STEMS 2.0 FAQ at top of tech support page here might just be a good idea as well.
A screenshot of your Audio Settings page would help.
I have the same problem
In the middle of the set the music stops randomly
I have to exit the app and re enter again
And actually my laptop is i7 and 16 gig ram
What can i do to stop that?
