Topic: A couple of things about smartfader
This video shows a situation with a 60 bpm track and a 155 bpm track set at 120 bpm, and the crossfader centered
That makes both bpms jump to below where any of them were to begin with. 40 bpm and 80 bpm
Although that is a match it seems a little strange.
Is that intentionally?
And the other example:
If you have a deck playing, load the other deck, press play, and then turn on smartfader, it will affect the playing deck, even with the crossfader 100% at the playing deck
It also happens if you enable smart fader before clicking play on the second deck
geposted Mon 09 Jan 23 @ 5:10 pm
klausmogensen wrote :
a 155 bpm track
I think you mean 115 :-)
a 155 bpm track
Yes - sorry :)
I have now seen the first FLX 4 user describe this issue in the FB group
Hi mate I'm the bloke that posted that on Facebook. I have found out the cause of the problem for me so I hope it works for everyone and I will be uploading a vid on that post to show everyone.
All I have to do was turn on quantize on both sides
The second problem above is fixed in the latest EA version
But the BPM match choice when there is a big gap, still seems weird to me:
It's a bit of a weird use case to activate smart fader halfway in the mix too though :p
