Topic: Virtual's sound is cracking
Good evening everyone..... I upgraded the virtual to (2023 built 7388.1922).... before that everything was working normally.... after the upgrade many times by recording or using stems 2.0 the sound gives me some breaks. .... momentarily.... is this happening?
My pc specs
i7 -->> 2.4GZ
32GB ram
nvidia rtx 6Gb
2 ssd samsung (1TB) M2
Below I show you the virtual configuration in the performance tab
geposted Tue 10 Jan 23 @ 9:58 pm
I am having the same issue since the upgrade. My PC specs are:
AMD Ryzen 7 6800H 3.2GHz Processor
NVIDIA GeForce RTX 3060 6GB GDDR6
16GB DDR5-4800 RAM
Seagate Backup Plus 5TB USB 3.1 (Gen 1 Type-A) 2.5" Portable External Hard Drive 5400 RPM
16GB DDR5-4800 RAM
I also have a Pioneer DDJ Rev7 Controller. Others have said to increase the latency in Virtual DJ. I did that, and it didn't appear to resolve the issue until I also adjusted the latency in the "Pioneer DDJ-Rev7 Setting Utility" software. This appears to be working for me.
My latency settings are these... if we increase it, how much should we set it?
And even if we increase it, do they have negative effects somewhere else?
