Hello, I am planning to buy a Pioneer DDJ-FLX6 and I am wondering if Virtual supports all the functions with this controller?????
geposted Fri 13 Jan 23 @ 8:21 am
Yes, officially supported, fully functional https://www.virtualdj.com/manuals/hardware/pioneer/ddjflx6/index.html
geposted Fri 13 Jan 23 @ 9:02 am
only for version 8.5 as it says in the link you sent or for newer versions,,,,,,I use version 2022
geposted Fri 13 Jan 23 @ 10:03 am
You will need to buy either a licence or subscription and update to the latest release.
geposted Fri 13 Jan 23 @ 10:32 am
@Kradcliffe 2023 or❓❓
geposted Fri 13 Jan 23 @ 11:22 am
https://www.virtualdj.com/download/index.html
You can always find the latest version there
geposted Fri 13 Jan 23 @ 11:43 am
