Hi,
I have irregular the problem, that the Song little move when I cueing with the CUE Button.
When i set a loop and then i press cue..cue..cue..cue the point of start move (see Pichtures).
Start Point
after a few CUEing
I have 2 LC6000 both have the same behavior. Wheel Adjust is 50%.
I look at the Cueing process of the mapping page and see that between the CUE random comes JOG.
The Problem is since i have the LC6000 (halv Year). At the first times I thought it was my error and i turn a little the Jog. But that was not the Problem.
I found the Setting JogVibrationProtection.
I hope that will help me. But it doen't help.
How works the JogVibrationProtection. What are available values?
I use the LC6000 in combination with the DDJ-SX. The SX don't have this problem.
Win10
build7403
EDIT:
I change the Mapping now and test it this night:
CUE
JOG
JOG_TOUCH
Start Point
after a few CUEing
Win10
build7403
EDIT:
CUE
cue_stop & set 'jogoff' 1 & wait 500ms & set 'jogoff' 0
JOG
var_equal 'jogoff' 1 ? nothing : touchwheel
JOG_TOUCH
var_equal 'jogoff' 1 ? nothing : touchwheel_touch
geposted Sat 14 Jan 23 @ 3:54 pm
