Topic: not able to use eq
Hi I'm not able to use my EQ knobs at all, your able to see them move while turning them but there no effect or kill switch at all. i'm not using Stems either. Please help
Thank you
geposted Mon 16 Jan 23 @ 4:51 am
If you want Full Kill for the EQs you need to change that from the default ..
to Full KILL for the setting equalizerFrequencySpread
also check all your settings under the Audio section in options, to see if any are not as you would like.
are you using a controller or can you also get same results with software only . (controller off)
after rereading.. when you mention kill switch.. that is on controller right? or which skin ?
More info . the more the answer can be what will help.
VDJ build and os info can help also.
