Hello,
My laptop dont find the divice ( Gemini G4V dj controller)
IM pro license member
where can i find a driver update for this G4v controller?
Its not on the gemini website aviable.
geposted Tue 17 Jan 23 @ 9:40 pm
The only thing u need is the Windows Gemini ASIO driver .. https://geminisound.com/pages/downloads
Other than that, it should be plug n play as per the manual https://virtualdj.com/manuals/hardware/gemini/g4v.html
If not working, maybe there is a USB detection and/or USB powering issue.
What is your operating system ?
If on Windows, you can see if working as MIDI device , by using MIDIOX or similar.
geposted Wed 18 Jan 23 @ 4:34 pm
