Topic: Vdj and denon prime go - Page: 1
I have connected my prime go to vdj all is fine except for 2 problems.
1. It will not let me select were speakers are connected on new hardware on my laptop. The Prime Go is blue but cannot click on it.
2. My denon go screen is stuck in comptermode with standalone underneath..any help would be appreciated.
geposted Thu 19 Jan 23 @ 9:25 am
Do u have install all drivers from denon correct and latest firmware on the gear?
Hi yes my denon is running 2.4 and i have installed all the drivers etc from denon site
All the mixer and everything is working fine from denon onto vdj just these 2 probs. Cannot access anything on my prime screen and cannot change the sound to mixer instead of laptop
If driver not properly installed, screen may not work.
Probably drivers were not properly installed (something has blocked them - Antivirus, Users permissions etc).
So after clicking on the PRIME GO button, you dont get the Denon Prime GO ASIO driver on Master & Headphones as shown here https://www.virtualdj.com/img/364569/31782/AudioSetup.png ?
Perhaps try to uninstall the Denon driver, restart computer and install again.
Ok will try thankyou
So i am in deno dj.
I av found standalone dj systems
Do i now download the prime go windows driver.
Do i need the prime go mixer connected to the laptop whilst downloading the driver or not.
Best would be to install the driver without the Prime GO connected, but should be ok if do the opposite.
Ok
So i have followed all that and i have denon playing on vdj. My denon screen is still stuck on computer mode standby.. I cannot select the speakers onto prime go on the laptop. Its not showing in the audio settings in vdj. I have installed the skin etc but no denon skin on mixer etc.
Ok i try that
Do you do support were u can jump onto my laptop to have a look if this fails etc pls.
Tried all that and still the same.
Just checking i do plug the laptop into the USB B port dont i. And not the USB MEDIA PORT. I am new to all this
Worth going through this - https://www.virtualdj.com/manuals/hardware/denon/primego/setup.html
You issue could be that you connected your primego to your laptop for the 1st time before you installed the drivers and windows has used a generic driver instead.
So you may also want to try to uninstall the usb device from device manager, while the primego is still connected to your laptop, the once uninstalled unplug the controller.
At that point, uninstall the denon driver and reboot your laptop. After rebooting reinstall driver and then reboot once more.
Once you have done that only then plug the controller back into your laptop. Wait about 15-30 secs for window to see the controller and use the correct drivers to install once more.
Finally fire up VDJ and see if it now works.
Is my laptop powerful enough etc.
87%
