Topic: Pioneer DDJ-SB2 Tempo issue
Hi guys,
I just switched to VirtualDJ and I am facing the following issue (VirtualDj Pro + Pioneer DDJ-SB2), after finishing the transition from Cue to Master if I try to change the Master tempo is not working, I move the knob all the way up and down and nothing, am I doing something wrong or there is any settings to fix that?
Thanks!
geposted Mon 23 Jan 23 @ 4:55 pm
I noticed that the pitch slider is not responsive until I moving it up and down 2-3 times, after that is getting activ but it's messing up the tempo and it sounds bad (to fast tempo change), is that related to the SYNC button?
