Topic: sideview '....'
hi,
i will show a shortcut folder with the verb sideview '.......'
When i use, sideview 'sidelist', sideview 'automix', sideview 'sampler' etc. it works fine.
But i can not call the name of my own shortcuts (Virtual Folder, Playlists)
What can i do?
sideview 'foldername' don't work
regards DennYo
geposted Fri 27 Jan 23 @ 4:01 pm
It should work if you use the full path
Works fine. Thank you :)
