Topic: Trouble Getting Quantize to work
Hi, I'm new to VirtualDJ and pretty new to DJ'ing overall. Anyway, I'm trying to set up Quantize so that when I bring a track in, and I'm not lined up perfectly, I'd like Quantize to correct this slip. I have globalQuantize set to 1/2 beat. Yet when I mix in a new track at the same BPM as the other track playing, Quantize doesn't automatically line them up if I'm off a bit. Hope this made sense. Thanks for any insight.
geposted Sat 28 Jan 23 @ 1:38 am
Smart Play is the setting to enable to automatically align beats when pressing play
Not sure yet if that's what drove this or not. I'll look into it a little more. Thanks a lot for the help.
And this great video by Klaus, may also be of help, covering other options, in VDJ.
Also keep in mind that Quantize (quantize_all) must be enabled PRIOR starting the deck. If you start the deck and THEN enable quantize, it will not do anything. In this case you just need to press "SYNC" instead.
