Topic: Mic_talkover without change sampler_volume
Hello, i search a function when i Press the talkover Button to reduce only the Decks without change the Volume from the Sampler.
I have tested:
Mic_talkover 0% 10ms & sampler_volume_master 100%
But the talkover overwrite the Sampler Volume.
geposted Sat 28 Jan 23 @ 12:43 pm
one of these will get you close
set $volManip 0 & deck master repeat_start volManip 25ms -1 & var $volManip 0 ? param_smaller 0.5 `deck 1 level` ? sampler_play 1 & set $volManip 1 : deck all level -2% : var $volManip 1 ? sampler_used ? : set $volManip 2 : var $volManip 2 ? param_equal 1.0 `deck 1 level` ? deck master repeat_stop volManip & set $volManip 0 : deck all level +2%
or
sampler_play 1 & set $volManip 0 & deck master repeat_start volManip 25ms -1 & var $volManip 0 ? action_deck 1 ? param_smaller 0.5 `deck 1 level` ? set $volManip 1 : deck 1 level -2% : param_smaller 0.5 `deck 2 level` ? set $volManip 1 : deck 2 level -2% : var $volManip 1 ? sampler_used ? : set $volManip 2 : var $volManip 2 ? action_deck 1 ? param_equal 1.0 `deck 1 level` ? deck master repeat_stop volManip & set $volManip 0 : deck 1 level +2% : param_equal 1.0 `deck 2 level` ? deck master repeat_stop volManip & set $volManip 0 : deck 2 level +2%
Or
sampler_play 1 & set $volManip 0 & deck master repeat_start volManip 25ms -1 & var $volManip 0 ? param_smaller 0.5 `deck active level` ? set $volManip 1 : deck active level -2% : var $volManip 1 ? sampler_used ? : set $volManip 2 : var $volManip 2 ? param_equal 1.0 `deck active level` ? deck master repeat_stop volManip & set $volManip 0 : deck active level +2%
Thx Loco, are u ever sleeping? :)
I tested:
set $volManip 0 & deck master repeat_start volManip 25ms -1 & var $volManip 0 ? param_smaller 0 `deck 1 level` ? sampler_play 1 & set $volManip 1 : deck all level -20% : var $volManip 1 ? sampler_used ? : set $volManip 2 : var $volManip 2 ? param_equal 1.0 `deck 1 level` ? deck master repeat_stop volManip & set $volManip 0 : deck all level +2%
But now the valume dont goes back, also after erase the script from the buttom.
I cant change the volume with the normal faders, too.
I sleep a couple of times a week
your edit will have problems
level will never be smaller than zero, try 0.01
