Forum: Wishes and new features
Topic: Auto Effects
There are dozens of Effects that can be triggered during a live mix at any time but many don't sound good or are not compatible with the track playing. I would love to see Effects on the Pads or an Efx menu reset with each song. When we click on an Effect the software will add it automatically where it sounds the best. Being able to have an effect hit at the right place at the right time will really keep things in phase and add a unique style to a track.
geposted Sun 29 Jan 23 @ 12:12 am
To answer part of your question, check that the settings option resetFXOnLoad is YES.
"To answer part of your question, check that the settings option resetFXOnLoad is YES."
By system default that setting is No.
The purpose of Auto-Effects is to have it set at Yes and be able to add Auto Effects based on compatible tracks each time a new track loads. This thread was a request not a question. Obvioulsy in Auto-Effects mode you would have to have them reset each time a different song is loaded.
