Topic: CDJ Export not working
I'm on MacOS Ventura. I'm using a MacBook M1.
I have two USB sticks. both are formatted in disk utility as Fat32 (as otherwise virtual dj will not recognize.
USB A i formatted in Rekordbox, it mostly functions in Virtual dj, but 1/4 of the time it will say Database Error and will not work. Right now it does not work. I loaded 400 songs (mp3) on it yesterday via virtual dj just fine, but today it says Database Error in VDJ. If I open it in Rekordbox it reads it fine. If I plug it into the XDJ700 it works.
USB B i formatted in VirtualDJ, loaded songs via VirtualDJ, and it's readable in Rekordbox. Everything works on the computer BUT the XDJ700 does not read it, so it's useless. The XDJ700 just prompts me to format (erase) the USB.
What am I supposed to do?
geposted Sun 29 Jan 23 @ 6:36 pm
Yup there's definitely a problem with the export and VDJ not reading the drives.
Ive been exporting but when I put the drive in my players it says the playlist is empty, reads fine in Rekordbox but VDJ is the problem.........
