Hi,
I'm trying to change the order of the decks on the Xone K2 when using a 4 deck mapping from 3,1,2,4 to 1,2,3,4, but I can't seem to get it to work.
By default it's on Automatic (1, 2, 3, 4) but the order that it works is 3,1,2,4. If I manually change it to 1,2,3,4 the same thing happens.
If I change it to 2,3,4,5 then the Xone right fader (4) doesn't control anything, but Xone faders 1 through 3 control VDJ decks 2 through 4.
If I change it to 3,4,5,6 then the 2 Xone right faders (3 & 4) doesn't control anything, but Xone faders 1 control VDJ deck 3 and Xone fader 2 controls VDJ deck 4.
If I change it to 2,4,1,3 then the Xone faders control the correct VDJ faders.
It seems to just be a problem when I assign deck 1 first in the 'Deck' dropdown in the mapping area.
Using latest version of VDJ (v2023 b7403)
Anybody got any ideas on how I can get this working as I want it to?
Thanks.
Thanks.
geposted Mon 30 Jan 23 @ 4:08 pm
Leave to Automatic and instead try to change the MixerOrder setting from Options
geposted Mon 30 Jan 23 @ 4:41 pm
Thank you, this has worked! :)
geposted Mon 30 Jan 23 @ 4:54 pm
