For those who use the scratch feature or the V-scratch and want to cut at the same time.
With a simple keyboard & shortcuts.
You'll have to create 5 shortcuts. I'll take an example that is not the only one way. X, C, V, B, N (just at top of the space bar).
First, the return to central pos of crossfader:
'V' action="crossfader" value="reset"
The two shortcuts to shift to left of right:
'C' action="crossfader" value="0" left side
'B' action="crossfader" value="4096" right side
With this three shortcuts you can instantly go to left or right or middle.
Then,
Two other shortcuts for temporary action, working as C & B
'X' action="crossfader" value="0" chek the temporary box
'N' action="crossfader value="4096" check also temporary
So with this five shortcuts you can totally emulate the cut.
Example:
Put you crossfader to middle & press N the crossfader will temporary cut the left deck
Put you crossfader to left then press B the crossfader goes to middle
Try lot of combination to get exactly the kind of cut you want.
This technique allows to scratch with mouse or hand (V-scratch) with left hand, WHILE your right fingers are on the shortcuts to cut.
Yes it is hard to be synchronized but with a lot of practice it can allow you to scratch like with real vinyl turnables+mixer.
FRUiT94
Then,
Example:
FRUiT94
geposted Fri 14 Nov 03 @ 1:01 pm
can you help me i need a good music where i can find it
geposted Mon 23 Feb 04 @ 5:02 pm
Try your local music store.
geposted Tue 24 Feb 04 @ 8:39 pm
lol
geposted Fri 16 Jul 04 @ 7:13 pm
I'm not being able to create the shortcut. How do i do that ??
geposted Fri 10 Jun 05 @ 3:19 am
Go to the options menu, the click the "shortcuts" tab. Then there's an "add" button on the right of the window.
geposted Fri 10 Jun 05 @ 11:31 pm
Hopefully you like the software Herman, and stop using the outdated cracked version 2.01
would like to see you as a full member soon :)
Good luck with the shortcuts and scratch practice :)
geposted Sat 11 Jun 05 @ 2:17 pm
You wanna give me $114 ?? So i can buy the software.
I'm not being able to mess with the shortcuts, they don't seem adjustable.
geposted Sun 12 Jun 05 @ 9:09 pm
It's because you are using a cracked demo...many bugs and sorry to say no support for cracked versions. Sorry. Just purchase the real thing and you will have all the support you need and access to shortcuts.
MS
MS
geposted Mon 13 Jun 05 @ 12:41 am
He's right you know...
I used to be a "sinner" and use the cracked version too, since it was only for me as bedroom-dj, and I had almost no means of paying for the program.
But the minute I got my credit-card from the bank I purchased it (true, I can prove it... :) ), I rushed to the VirtualDJ site, and bought it.
And I must say : I have absolutely no problems anymore using this software. It is worth every EUR I spent on it....
Also, since I used the cracked version, I had the common sense not to bug the people in this forum, since I felt I had "no right of speaking" (figure of speech), untill I had the full version.
Sorry to go offtopic, but I had to get this off my chest....
geposted Mon 13 Jun 05 @ 2:40 pm
Look I need help here. How do I change the key???
geposted Tue 21 Jun 05 @ 10:25 pm
its ok i got it !!!!!! thanks for your help!!
geposted Tue 21 Jun 05 @ 11:04 pm
