Topic: Export
So in my quest to get this to work right with VDJ I have discovered that when just picking a playlist and then hit export it rarely works for me.
Instead I have to “create” a playlist on the “CDJ EXPORT” drive of my choice, then go back to the playlist and select all of the tracks. Now I go and drag all the tracks to the playlist I just made on the CDJ EXPORT drive and only then will it actually export the tracks.
Something seems to be wrong/broken somewhere in the chain.
Can any devs take a look?? Or am I doing something wrong here?? I can make a video showing my process if needed but this is really annoying considering I should be able to just select what I already have made and export it 🤷🏾‍♂️
geposted Sat 04 Feb 23 @ 7:33 pm
Ok I guess this isn’t an important enough feature 🤦🏾‍♂️
