Topic: Flx4 is unusable with smart fader
Was looking at changing from rekordbox to vdj so thought I'd give it a go.
Everything works fine if I don't use smart fader.
With smart fader active vdj is unusable.
I will have a track playing on side 1 that's bpm is 128 and I have a track on side 2 that is also 128 bpm and the crossfader is 100% on side 1.
When I push play on side 2, side 1 with frezzer shortly or bpm drop and it happens every time I push play on side 2 for random amounts each time and the crazy part is the bpm guage dose not change or show that it's having any effect other then the littling block that rotates around.
Is there a fix for this please?
geposted Sun 05 Feb 23 @ 5:25 pm
The issue is resolved with having quantize on on both sides
