Topic: map "search similiar songs" to hot key?
Is it possible to map this right click menu to a hotkey on keyboard or on my controller?
map "search similar songs" to hot key?
Steve
geposted Mon 06 Feb 23 @ 1:58 am
doesn't it really only put artist title into the search bar?
It does more than that for me, it lists all available versions of the track I am searching... (Intro edit, remixes, etc..) Do you know how to map it to a keyboard key?
I'm not sure it does, I think everything else is because of the search.
get_text "`get_browsed_artist` `get_browsed_title`" & param_cast & search
Yes, that worked, I appreciate the code. It is not exactly the same output as the right click output, but close enough for my needs. I am trying different tweaks with your code to see if I can get it exactly the same. I will post if I get it.
Doesn't that bring results as same song being played
All the right click option "search similar songs" seems to do is (as locodog said) put the artist & title in the search box - so it would be more accurately described as "search for exactly the same song".
Yes it will pull up any remixes, but they're not "similar songs".
