Topic: Unable to save Stem on PAD Mode
I'm not sure what happens, but I'm now unable to save the stems to PAD Mode. It was to be on the loop roll, and it shows that it's on there, but it's not showing on the controller or the software. You can add it, but as soon as you switch to another pad mode, like hot cue, it will return to the draft pad mode.
geposted Thu 09 Feb 23 @ 12:07 am
So I figure out the problem. I had the change my mapping back to factory default and everything went back to normal...
