Topic: Performance Layout - Panel Default
I'm using 4-deck Performance Layout.
I would like to reconfigure one of the panels - currently "PADS" is the default.
I would like to change that to Effects.
How can I do that?
geposted Thu 09 Feb 23 @ 10:46 pm
This (default) is only a part of Pad panel name.
There are 2 versions of Pad view. (default & 4 btn)
default -> drop down for change pads
4 btn -> 4 pad page buttons on the top. Like many Controllers.
Oh okay, thank you DENNYO BEATS!
So there's no way to make FX to always load first in that panel?
Normally it starts with the last open panel.
You can copy this script to the oninit of your keyboard or Controller.
skin_panel '@fxknobs_deck1_compact' on & skin_panel '@fxknobs_deck2_compact' on & skin_panel '@fxknobs_deck3_compact' on & skin_panel '@fxknobs_deck4_compact' on
Thank you @DennYo for your suggestion - i will give it a try!
I got a word from VDJ support that this is not possible to change at this point.
wow thank you, DENNYO BEATS, this script works beautifully and does exactly what I wanted.
much appreciated!
