Is there any update on stem extraction using Intel Arc GPUs?
geposted Sat 11 Feb 23 @ 2:15 pm
Should work fine with the higher end ones
geposted Sat 11 Feb 23 @ 2:35 pm
I have been informed by VirtualDJ support that they do not intent to ever support Intel Arc GPU's and they will not work for stem extraction.
geposted Sat 18 Feb 23 @ 7:40 pm
While the lower end may not be suited, we do have reports of the Intel Arc A770 working at 10x real-time for stems 2.0
geposted Sun 19 Feb 23 @ 1:59 pm
I tried searching and hopefully I didn't miss this somewhere in the help posts...
I have 2 Laptops, both have essentially the exact same specs, one's a Lenovo Yoga & one's a Dell Plus 2 in 1.
Both have:
Intel Core Ultra 7 256V (2.20 GHZ) Processors
Intel Arc 140V GPU (8GB)
But when trying to Run Stems 2.0, the Lenovo will use the Intel Arc GPU and does a surprisingly good job with it (GPU usage 100%) but the Dell will NOT allow me to use the the GPU and every time I try, it automatically switches the stemsFix option back to "Don't us GPU"...
Any help would be appreciated b/c it IS apparently possible. I've tried it on both V2025 b8678 & also the b8729 but no luck on the Dell...
Thanks in advance!
Both have:
Thanks in advance!
geposted Tue 23 Sep 25 @ 8:58 pm
