Topic: DMX pad lighting
Hi all,
I have connected my DMX controlled lighting (Freestyler) system with VDJ.
Light effect works fine but the pads don't light up in the VDJ nor on my controllers.
When I press a button, I don't have any visual feedback. The pads do not illuminate.
So I don't know which light effect is currently active.
Does anyone know how should I program the pads? What script do I need and where should I enter it?
I would like it like for example "stems"
Many thanks for the help!
geposted Sat 11 Feb 23 @ 7:58 pm
Hi all,
I have connected my DMX controlled lighting (Freestyler) system with VDJ 2023 pro. Light effect works fine but the pads don't light up in the VDJ nor on my controllers. When I press a button, I don't have any visual feedback. The pads do not illuminate. So I don't know which light effect is currently active.
(If only VDJ is open and Freestyler is not, then the PADs will be lit. But if both programs are running, they no longer light up.)
I would like if the pad LEDs worked like at "Stems“effect
i have the same problem
the colors on my Samples are working because i choose it in the sample editor
but for my custom pad where my push to talk is its not wokrking anymore
either all lights are grey or they take the color from the pad menu what was active before
any help?
BUMP
