Hi when starting VDJ once the controller is already powered up I need to play with some of the buttons in order to reset.
EX. if I put a song in the deck and press play the sound comes from my speakers although the sliders are down. I need to move the slider all the way up and back down in order to reset.
Same thing for the cross fader. I don't like using it so set the controller switch to thru setting but I need to go and slide the slider to left then right then back to thru on all 4 channels in order to deactivate.
Any way around this kind of a pain to do this every time.
Thanks
Thanks
geposted Sun 19 Feb 23 @ 11:44 pm
Windows, right ?
You will need to install the Denon Windows driver for the positions of the faders to be reported on startup.
geposted Mon 20 Feb 23 @ 4:50 pm
Hi yes windows. And I did install the denon drivers for the mc6000MK2 yesterday and makes no difference. Just tried again now
Thanks
Thanks
geposted Mon 20 Feb 23 @ 5:04 pm
And firmware is updated to the latest version v1003.01 ?
geposted Mon 20 Feb 23 @ 5:25 pm
Yes firmware just checked and is the latest
geposted Mon 20 Feb 23 @ 10:59 pm
Ok after speaking to tech support I have a partial fix
In Onit I entered the following code: deck all volume 0% & master_volume 0%
that works for the volumes at inital start being set to 0
But can't figure out for the faders how to set it to initail start at Thru instead on switching the 4 switches to reset them.
I think the code is CF_THRU
thanks
thanks
geposted Thu 02 Mar 23 @ 6:42 pm
Also add & deck all cross_assign 'thru'
geposted Fri 03 Mar 23 @ 8:52 pm
