Topic: Automatic POI
I downloaded some music from crate connect.
When I load song in VDJ there are automatic markers and cue points.
Other songs that I already have I know there is POI editor which shows automatic markers and cue points but I need to set each one by one from Invisible to either marker or cue.
Can this be done automatically like songs from Crate connect?
Thanks
geposted Sun 19 Feb 23 @ 11:47 pm
There is no such automatic Cue/POI detection. VirtualDJ can read Cue POIs from Tags (if exist) and having getCuesfromTags setting to "new Files" or "always". Useful when you have set those with another software that saves Cues to Tags (such as Serato)
if you mean make invisible points like automix / remix, into visible, it can be done but not in vdj, it needs some regex wizardry on the database @xml level, If you can't do it I do that kind of task for a beer or two.
Ok thanks since the songs I download from crate connect already have the cue points set up and automatically visible in VDJ without touching anything I thought there was an easier way for the songs I already have.
I guess Crate Connect like mentioned has these in the tags.
