Hi all, just to be sure...
I have the newer GT version of the DDJ-FLX6 and I really like VDJ with it's stems options, that Serato Pro and Rekordbox can't give me. So I want to buy a Home Plus License but will my controller work with the (older) DDJ-FLX6 license option from the pulldownmenu on the buy page? Because I don't see a DDJ-FLX6-GT option.
Is VDJ updatable to newer versions with the Home Plus License?
geposted Mon 20 Feb 23 @ 9:00 pm
From what I know FLX-6 and FLX-6 GT are the same in terms of system, the difference is in cosmetics ( colors) and some material quality (jog wheels). FLX-6 GT was made to replace the FLX-6 so you should be fine with DDJ-FLX6 License.
geposted Tue 21 Feb 23 @ 3:24 pm
^ that's correct
geposted Tue 21 Feb 23 @ 3:28 pm
Thanks!
geposted Tue 21 Feb 23 @ 3:40 pm
