Is there only 1 way to stop recurse on a main folder ??
geposted Fri 24 Feb 23 @ 3:38 pm
Just browse to another folder and recurse will stop
geposted Fri 24 Feb 23 @ 3:41 pm
Phantom Deejay for some reason when i start VDJ it will scan my main folder every time on my external hard drive this didnt happen until updates.
geposted Fri 24 Feb 23 @ 4:11 pm
Regarding recurse, make sure RememberRecurse setting is set to No, so that next time it doesnt keep the recurse you ve set on a folder.
As for scanning Tracks when a folder is focused, you may want to set analyzeSongsonView to No
geposted Fri 24 Feb 23 @ 4:25 pm
would there be any other reason why VDJ is doing Get Status ,subfolder check every time
geposted Fri 24 Feb 23 @ 8:39 pm
