What is the method to change the setting: levelfaderHamster with a script from No to Yes, or set Per Deck?
the following below do NOT work, to toggle the No to Yes:
setting 'levelfaderHamster' Yes
setting 'levelfaderHamster' 1
setting 'levelfaderHamster' true
ie: how to set all the possible configurations of levelfaderHamster with a script.
geposted Sat 25 Feb 23 @ 1:25 am
If all you want to do is toggle then use this:
deck all setting 'levelfaderHamster'
geposted Sat 25 Feb 23 @ 2:24 am
Thank you PhantomDJ
That will work for my needs .. works perfectly !
Which toggles between: No AND all Per Deck: to Yes
Again Thanks
Again Thanks
geposted Sat 25 Feb 23 @ 2:39 am
