Paused for a second then continued to play then after 20 minutes audio output became crackly
Had to reboot system to get it to work but then the same fault
This has happened since last vdj update
geposted Sun 26 Feb 23 @ 1:46 am
I have been having the same issue with different controllers and computers something in the VDJ software is off
geposted Mon 27 Feb 23 @ 4:47 pm
Exactly... there is something seriously wrong with VDJ since the last update.
The sound becomes distorted/crackling after a while, very annoying, basically makes it unusable for my next gigs.
It might have to do something in combination with recent Windows 11 updates, but not sure.
I have tried many NVIDIA settings, but results remain the same...
geposted Mon 27 Feb 23 @ 8:52 pm
