Hi everyone, I'm using DDJsx2,while crossing from Deck A to Deck B on my console the crossfader bounces and turns back to a random value on vdj. It happens when I cross very quickly from one Deck to another. On the other hand when I cross slowly from one Deck to another the knob arrives to a desirable value on vdj but begins to oscillate. Is It a problem of console (dust, oxides etc) or just of some settings to be adjusted? Thanks.
geposted Sun 26 Feb 23 @ 1:32 pm
Sounds like fader bleed to be, maybe compressed air will sort it out.
geposted Sun 26 Feb 23 @ 1:49 pm
Buy some good quality swith cleaner (serbisol 10), some fader lube, (search on ebay)
If that does not cure it, than it need a repair...
geposted Sun 26 Feb 23 @ 4:59 pm
