DJ' ing for couple dancer. I play the full song , then i have about 1 or 2 Seconds of silence to give the dancer the chance to thank each other for the dance an decide wether they have another dance or not. So it would be great to have in the Options -Automix- Skiplenghts the possibility to put negativ values to create a silence between the songs. Actually you can fill in only positiv values for fading.
geposted Tue 28 Feb 23 @ 9:28 am
setting fadeLength as a negative number
geposted Tue 28 Feb 23 @ 9:39 am
I've never thought of that :D
I knew about the 2 sec gap option in the dropdown, but had never checked how that registered in the settings, and if it could be changed it further
Good stuff!
geposted Tue 28 Feb 23 @ 10:31 am
Nice …
Though I would prefer a dedicated setting or a different control label if selection is "None (back to back)".
No-one can remember this peculiar feature a few months later.
geposted Tue 06 Jun 23 @ 6:58 pm
Set
fadeLength = -2.0… Didn't work. Songs were played without pause, one after the other.
geposted Tue 13 Jun 23 @ 8:16 pm
OK, here's a hint to the solution: You must select one of the Fade Automix modes.
Only then, fadeLength is being considered. The GUI then adds a dedicated Fade Length sub menu to the Automix menu. And this sub menu even comes with a preset value of "-2", aka "2s gap":
geposted Fri 23 Jun 23 @ 4:57 pm
It does indeed work setting it in the settings:
geposted Fri 23 Jun 23 @ 7:17 pm
