i have a Zbook 17 g6 17" Laptop 128GB ram Core i9-9880H 2.30GHz 512GB hard drive with a quadro rtx 4000 . when i do the stems its take a bit of time on it with standard set up but when i change the gpu to the nvadia side its a little bit quicker .... i guess im asking is there a difference between the quadros rtx ant the rtx setups as far as doing the stems i need some help with this
geposted Tue 28 Feb 23 @ 8:43 pm
