Topic: using 4 decks
Hi all,
Sorry if this is a really easy question, been scouring for a while and haven't found the answer. In the old versions of VirtualDJ, there was a little dropdown thing on the top that let you select how many decks you wanted visible. This was really helpful for me. In the newer versions, that option is gone, replaced by something that lets you select the general format/design of your interface. I know it's still possible to go back to the old design (I found it in the settings menu), but I was wondering if there's some way to switch to 4 visible decks on the current design that I'm missing because I'm not as used to the new update.
Thanks for any and all help.
geposted Sat 04 Mar 23 @ 8:22 pm
pro & performance have 4 deck variations in the layout dropdown, essential & starter do not have 4 deck variations
geposted Sat 04 Mar 23 @ 8:47 pm
Oh that makes sense. Thank you
geposted Sat 04 Mar 23 @ 9:40 pm
