I would really appreciate any information on using installed extensions. Thanks for Your responses.
geposted Fri 10 Mar 23 @ 1:30 am
Extensions come in may categories, (each w sub-categories) and hence a wide variety of uses.
Maybe start here:
https://www.virtualdj.com/manuals/virtualdj/settings/extensions/index.html
https://www.virtualdj.com/manuals/virtualdj/appendix/nativeeffects/index.html
Maybe start here:
geposted Fri 10 Mar 23 @ 3:38 am
...I did that this is the instruction to use "Once installed you can now use the new extension by going to that section of the software." I don't mind saying that's mad vague to somebody who has never navigated even finding anything in the software before...once again Thank You for Your assistance.
geposted Fri 10 Mar 23 @ 4:11 pm
Is there something you are trying to add?
(can easily help you find that extension after you have added)
As mentioned there are many diverse extensions, and each found in different locations after being added.
Adding a sampler bank would be found in samples,
Adding FX effects .. in FX effects
Adding a skin ..
Adding padpage...
adding a custom mapper ...
etc..
etc...
(I count 19 different types of extensions)
And if you wish specific info for any particular extension, click the "Comments" link for that extension, to take you to the thread which discusses that extension.
Hope that gets you a step closer
Adding a skin ..
Adding padpage...
etc..
etc...
geposted Fri 10 Mar 23 @ 5:15 pm
Dude I appreciate You...check out Your help's outcome...11-1am The Conscious Champion Sound Hour...wcrsfm.org
geposted Fri 10 Mar 23 @ 8:58 pm
