Hi I just purchased some audio technica 120xusb turntables. I have a denon mc6000mk2 controller. using phone or line setup doesn't make any difference wile using dvs timecode. Although I find there is a delay in reaction especially while moving the pitch slider. Can I use the USB cable and connect the 2 turntables directly to the pc? Will this give better results or just made for recording? The reason I just don't try is because the pc is further away than my setup therefore need longer USB cables. If worth it I will buy but not just to try?
What is the best way in connecting these turntables? Line,phono or USB?
If i use USB directly to pc can my controller control the turntables?
I had a technics 1200mk2 and also had a delay in reaction
Thanks
Thanks
geposted Sun 12 Mar 23 @ 4:14 pm
