Quick question how do you actually bypass time code when I want to play real vinyl? I read a few things but nothing makes sense. The main thing that comes up is I have to switch to line out but does this mean I need to connect cables to line out on my mixer or is this a shortcut on the main screen? Any help would be great and I’m using an Allen and heath xone 23c mixer.
geposted Mon 13 Mar 23 @ 7:04 am
Once you have set up timecode in your audio config, and setup a deck to be controlled by it, you can select bypass in the timecode dropdown on the deck:
geposted Mon 13 Mar 23 @ 7:09 am
Great stuff cheers
geposted Mon 13 Mar 23 @ 7:14 am
