I purchased the monthly subscription to the idjpool streaming. All the songs are coming up as the 30 second samplers. What do I need to do to get the full song to load on the decks?
geposted Fri 17 Mar 23 @ 3:57 pm
There is no purchase of anything under the account you used to post here. See if you had used a different email and create a new account, and then re-login.
If the same, perhaps the purchase didnt go through (some bank charging issue), in this case contact Support https://www.virtualdj.com/help/
geposted Fri 17 Mar 23 @ 5:32 pm
