Hello, is it possible to help me?
I am new in Virtual Dj and I would like to have the pads like in Serato, the most important thing I want is for the first pad to be an automatic Cue Loop but the rest of the pads to be only hot cues without loops
I tried in the Pad Page - Cue Loop button but it makes me press the same button twice, and in Serato this thing is automatic
So I repeat, I want the first pad to be Cue Loop - and the following ones when I press them to be just hot cue without loop
I also tried at Custom but I gave up and said I'll try here because you probably you know how to do it
Thanks is advance
Thanks is advance
geposted Sat 18 Mar 23 @ 7:29 pm
