I just recently purchased the DDJ-FLX4 and love the controller. Years ago I had a pair of Stanton c.304 turntables which had a feature called "Touch Rewind". Whenever you would touch the jog wheel, it would rewind to the last selected cue point and you could proceed to scratch from there. Is it possible to achieve this same behavior with the DDJ-FLX4 while using VirtualDJ?
geposted Tue 28 Mar 23 @ 8:27 pm
disregard. i seemed to have figured out the action by using the following for JOG_TOUCH
down ? touchwheel_touch on & goto_cue : touchwheel_touch off
geposted Tue 28 Mar 23 @ 8:43 pm
