Topic: VST3 Support
In new version of virtual dj is not comptitible for vst plugins because after updating i can't see any my vst plugins . so anyone have solution for this
sorry for my bad english.
geposted Thu 30 Mar 23 @ 3:45 pm
Maybe you have gone from the 32-bit version to the newer 64-bit version
In that case none of your old vst FX will work
The default folder might have moved as well. At least on the mac it went from ~/Document/Virtual DJ to ~/Library/Application Support/Virtual DJ.
Als in new version you can now enter a default folder for VST effects (instead of the folder inside VirtualDJ folder)
